2001 F550 no WTS, no tach - Ford Powerstroke Diesel Forum
Old 10-05-2011, 03:40 PM
Well, i've been having issues for the past 3 weeks almost now.
up untill today the truck would start fine cold, WTS worked, Tach worked.
Truck stalls after being run for 10 -30 mins
Won't restart for several hours.
I have done all the easy stuff
oil change, fuel filter, CPS, unplug ICP, rebuilt IPR.
When the motor cranks warm the ICP reads .5 - .55 volts
When cold cranked it reads .935 and fires up.
I read somewhere that the ICP is suppost to have 12 volts to it. Mine had 5 volts
So I jumpered a wire from the battery to the ICP and tried that.
Bad move. I read now that it should have 5 volts...
Now no WTS, no tach signal.
Changed out the CPS again and still no tach.
Checked fuses with DVOM and all zeroed out.
I should specifically check fuse 19, 22, and 30 again but I checked every single fuse under hood and under dash.
Did I fry my PCM trying to jumper 12v to the ICP?
Old 10-05-2011, 05:36 PM
Double checked fuses, all good. What about the PCM relay in the engine fuse box? Could I have shorted that by jumping the ICP.
I tried to pull codes and my superchips would not connect.
It read codes yesterday, now after my lapse in judgement, it wont read codes.
How can I check the PCM with a DVOM?
Old 10-06-2011, 12:12 PM
My guess is that the PCM is fried. Tach gets its signal from the PCM. I don't know if you can check the PCM with a DVOM, but I'll look at a PCED (Powertrain Control Emissions Diagnosis) manual to see what might be able to be checked (although I can only go to a 96 PCED and your's is a 2001. Cheers!
