Fuel leak - Ford Powerstroke Diesel Forum
Old 10-03-2011, 06:23 AM
Fuel leak
Well I have a pretty good fuel leak on my truck 95 f250 and I don't know where it's coming from, I just replaced all the orings on my fuel bowl, replaced all rubber fuel line. What is a comon place that they leak??
Old 10-03-2011, 06:33 AM
It could be the fuel pump, or the banjo bolt on the back of the fuel pump. I had a leak from a sensor on the back of the fuel bowl. I can't remember what its called, but fuel was actually leaking out of that sensor, not where it connects to the fuel bowl.
Old 10-03-2011, 06:36 AM
Ok well I'm gonna wash the motor during lunch and see if I can find fresh fuel on just one spot...
Old 10-04-2011, 08:10 PM
fuel pump is a VERY common leak, just got done doing mine a/b 2 weeks ago. not too hard. looks harder than it is.
also the black sensor on the side of fuel filter housing is known for leaking as well..
Old 10-04-2011, 08:17 PM
Shaking the Bush Boss
the sensor is a vaccum switch, it operates the fuel filter light in the dash. It'll leak when the engine is running. I cant rember if its on the back side/bottom of the fuel bowl on a 95 or not, my 96 was on the fuel regulator. Its known to leak. Save yourself some $$$ and go to lowes/ home depot etc, and buy a pipe plug instead of buying the sensor from ford...75.00 IIRC.
Old 10-05-2011, 04:47 AM
Well that sensor is gone and has a plug in it so I doubt that's where it's leaking, I THINK it's coming from the banjo bolt on the fuel pump, anybody have any part numbers for the crush washers?
Old 10-05-2011, 05:16 PM
Here ya go:
Fuel Pump Banjo Fitting Seals (seals the banjo fitting of the "wishbone" line)
(Ford) F4TZ-9A375-A
(International) 1820650C1
Aeroquip # FBM 3517
Cheers!
Old 10-09-2011, 09:20 AM
Does anybody know if I can get the crush washer from my local part store? Thanks
Old 10-12-2011, 03:21 PM
Get it from your local International parts dealer
Old 10-15-2011, 07:46 AM
that big bolt thru the banjo is probably just loose....get a big box endwrench, (can't remember what size ....1 5/16 mebbe) and tighten the crap outta it...those should be copper washers, and leak if not guddentite.
