need some advice on ebp sensor codes
just purchased this truck and noticed that when first start up acts like wants to die out. also when decelerating off throttle in gear or neutral, vehicle acts like stalling out. like is in 5th gear doing 10 mph
so i then pulled out my ole scanner and pulled history code of p0470 ebp sensor code. removed sensor and cleaned tube, both very restricted. still no change ![]() so today figured i would pull codes again and now have p0472, & p0476 any ideas. figure is probably bad ebp sensor but defenitely want to make 100% for sure before i shell out $100.00 since i just lost my job. ebps reading on scanner was 20 psi before cleaning and now is at 17 psi, not sure what spec should be.. thanks in advance. |
Maybe the....
Could the solenoid be bad, or the actual valve stuck partially closed?
Disconnect the solenoid and make sure the valve is all the way open. See if it runs better that way. Check that out first |
