I just had a Brain fart, Theres oil in the valley. and if the seal is leaking then its the IPR. Ill replace and let you no!
Wasnt it
You have pretty much tried everything you can externally. The IPR o-rings didn't do it?
Do you have the means to check fuel and oil pressure? I think you are on the right track with pulling the valve covers and diving in as your next step. Maybe the UVCH or injector rings as you mentioned. Is it a standard trans or auto? Reason I ask is mine was doing bizarre inconsistent rough idle, lack of power shannanigans and I went through ALL the same stuff you are going through. In the end it turned out my dual mass flywheel had about a 1/2 - 3/4" of play in it...which I thought was sort of normal. Went to a solid flywheel and away went all my problems. Just something to keep in mind and you might want to pull the inspection cover it it's a ZF5 and have a little look see. |
Yeah I no. I need a scanner can't find one. I'm gonna test the lift pump then well see
It's the uvc harness. Mine did the same thing that's why I replaced all the parts either get a shim or look up the 50 cent mod
Also if the The ipr made the problem worse it's because it was actually improving oil flow to the injectors but the electrical can't keep making the injectors operate right which is why I say the UVc harness.
Well i dont want to just throw parts at it, Im gonna install the origanal one back in it.
My dad bought those ones from you, though us. And hes short on cash, so You said we can return them if it didnt work. So on our aggreement we can do that. Thanks man. |
Two things,,,,, not getting hpo or fuel.
Im gonna check the HPOP pressure, and Pour Fuel in it soon.
