Starts, runs smooth for a minute, then lopes/misses, and dies. - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-29-2011, 12:18 PM Thread Starter
Boss.Hoss's Avatar
Hey guys,
My 96 7.3PSD has stumped me for a while now. It starts okay, idles smooth as a baby's bottom for a minute or two, then lopes badly for 15-30 sec and shuts right down. Will not restart unless I let it sit for a while, sometimes a few minutes is enough, but it just repeats the same symptoms.
It doesn't set a CEL. Ive watched fuel pressure at the schrader valve and it doesn't drop off. Bounces around 55-65 the entire time. Doesn't leak down after it dies either. HPOP res stays full. Fuel bowl stays full. I thought maybe it was the IDM, I pulled it apart and it did have some moisture in it. I cleaned it well with contact cleaner. I'm not sure I think it the IDM anymore with how repeatable the issue is and the fact it runs fine at first. Maybe the HPOP isn't pumping after it warms up? But you wouldn't think it would act like this... Truck has 340,000 and AFAIK its never had injectors or HPOP done. Just glowplugs/relay and a turbo and a few clutches and some pulleys. I swapped out the CPS just in case, but no effect.
EDIT: I did remove my pot from the ICP circuit to take it out of the equation. Is there any chance I could have hurt something in the PCM by having it in there? I believe it is a 0-10k pot, I did add a resistor inline so I could never go below a certain resistance, maybe 2 or 5k? Don't recall.
Any ideas without access to a scantool? Can I monitor hpop press using the icp sensor and a voltmeter/ohmmeter?
96 SCLB F-250, 4x4, 5spd
900ft/lb Valair Clutch/Solid Flywheel
3" MBRP downpipe
4" MBRP Turbo-back in to dual 5" stacks, all straightpipe.
DIY Tymar Intake
BB in FPR
Potentiometer in ICP circut
VDO boost and pyro gauges on the A-pillar
Coming soon:
TW Chip
D60 swap
RSK/SD springs up front
Shackle flip in rear
Homemade traction bars
Rosewood Stage 2 sticks
Intercooler
Boss.Hoss is offline
post #2 of 10 Old 09-08-2011, 02:02 PM Thread Starter
Boss.Hoss's Avatar
No lovin' for the Hoss man?
I did end up reading of a similar issue that was resolved by cleaning up the battery connections... I did that it deffinately helped... I was able to drive the fuel station and back without issues, the next day it idled in my yard for about 20 minutes then loped for 2 minutes and shut down again... must be more electrical gremlins somewhere... I thought it was fixed... False alarm..
Any other ideas guys?
3" MBRP downpipe
DIY Tymar Intake
BB in FPR
Coming soon:
TW Chip
D60 swap
Intercooler
post #3 of 10 Old 09-08-2011, 03:24 PM
1tonpower's Avatar
Send a message via AIM to 1tonpower
hows the oil level look
08 f350 KMC wheels with 33" MTZs, bed rails with a reese 20k slider, 5% tint all around, 60gal fuel box, kenwood monitor, afe drop in filter, livewire w/innovative tunes, sinister egr delete, twisted stage 3 trans
1tonpower is offline
post #4 of 10 Old 09-08-2011, 03:30 PM Thread Starter
Boss.Hoss's Avatar
Oil pan is full. This truck never uses or leaks any oil, even after 340K+ miles! The HPOP resivioir also stays full. I think its electrical. If it starts loping I can turn the key off and back on while I'm going down the road with it in gear, and the misfire will go away for another couple minutes.
3" MBRP downpipe
DIY Tymar Intake
BB in FPR
Coming soon:
TW Chip
D60 swap
Intercooler
post #5 of 10 Old 09-08-2011, 03:43 PM
Chop's Avatar
Have you changed the CPS ?
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
post #6 of 10 Old 09-08-2011, 03:56 PM Thread Starter
Boss.Hoss's Avatar
Yes, as mentioned in the OP, I chainged the cps though I was still getting tach signal with the old one. No effect.
3" MBRP downpipe
DIY Tymar Intake
BB in FPR
Coming soon:
TW Chip
D60 swap
Intercooler
post #7 of 10 Old 09-20-2011, 02:58 PM Thread Starter
Boss.Hoss's Avatar
Well, finally found a used IDM for $50 online and tossed her in... all is well. guess this goes to show, GO WITH YOUR INSTINCTS! That was the first thing i suspected and i did find moisture in it, just didn't want to drop the coin for a new one!
3" MBRP downpipe
DIY Tymar Intake
BB in FPR
Coming soon:
TW Chip
D60 swap
Intercooler
post #8 of 10 Old 09-20-2011, 03:21 PM
Chop's Avatar
Congratulations on your gremlin elimination,your first thoughts seem too always be the answer don't they?
Chop is offline
post #9 of 10 Old 10-08-2011, 04:44 PM
Spud Monkey's Avatar
These IDM's go out that easy?
Spud Monkey is offline
post #10 of 10 Old 10-09-2011, 04:42 PM Thread Starter
Boss.Hoss's Avatar
Yup, they are prone to getting water in them due to their placement on the inner fender right beneath the hood-fende seam. I pressure washed my truck (the exterior, NOT under the hood) and I apparently got water inside which smoked the high voltage circuitry inside. These things produce 100VDC, so any kind of moisture that makes it in can be very easy to break things...
3" MBRP downpipe
DIY Tymar Intake
BB in FPR
Coming soon:
TW Chip
D60 swap
Intercooler
