f350 loses power and stalls - Ford Powerstroke Diesel Forum
Old 06-28-2011, 12:37 PM
Well my 96 f350 stalled on friday going up a hill pulling my trailer.......the day after I got it. the trailer doesn't weight much, its a 70s camper that's been gutted so I'm not thinking that played any factor in this. one thing I've noticed is that even if I lay my foot into the skinny pedal I cant make it smoke at all. So as I'm coming up the hill it loses power and dies. I try starting it and it sounds like it wants to fires every couple cranks but nothing. I change the CPS......and nothing. I also change the fuel filter and after cranking it a couple times I check the fuel filter and it's still dry. At this point I'm thinking fuel pump. Any suggestions? I've been told this truck only has the mechanical fuel pump at the motor but a shop I called insists that there is one at the motor and one in the tank.
Thanks!
Old 06-28-2011, 06:33 PM
any suggestions?
Old 06-28-2011, 11:12 PM
What was the fuel level when this happened?
Old 06-29-2011, 09:00 AM
I'm not sure exactly but I had only gone 100 miles or so since the front tank was filled. I believe each tank holds 19 gallons. the fuel gauge doesn't work so my plan was to go about 200 miles on each tank then fill
Old 06-29-2011, 09:22 AM
The guy at the shop said he was messing with the fuel lines a little and he got it to almost start but it was pouring whitish grayish smoke from the turbo. not the exhaust but it was coming from the turbo itself.
Old 06-29-2011, 09:29 AM
sounds fried to me, and my f250 wont smoke at all no matter what unless i put a tune on it
Old 06-29-2011, 09:33 AM
when you say fried?
Old 06-29-2011, 09:35 AM
well you say the smoke is directly from the turbo rite? not the turbo outlet, or ehaust, you say the turbo it self is smoking, im not sure on this, just thinking aloud here
Old 06-29-2011, 01:55 PM
I'm thinking the smoke was just some turbo leak. i know, turbo leak isnt good but it shouldnt keep it from starting. there is no smoke at all from exhaust. I unplugged what I "think" was the fuel bowl heater any tried to start. I also unplugged what I "think" was the ICP and tried to start. nada from either. The tach reads rpms, looks like about 200 or so, possibly a little more or less. fuse #4 was blown though I couldn't figure what fuse number 4 actually does. so I replaced it an nothing. The fuel bowl was still empty so I fill it to the top with diesel and put it back together and try cranking. nothing. I do get a WTS light so I'm thinking IDM at this point. any input?
Old 07-01-2011, 10:54 AM
any input would be much appreciated, I need this truck to be back up and running. I'm sure some of yall have had this same thing happen
