dies when warm. not icp or cps - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-20-2011, 10:34 AM Thread Starter
So after 20 minutes of driving or so my truck just dies. No warning or anything. No codes. No mods. Swapped icp and cps and it still does it. After it sits for a while it starts back up. Any ideas?
2007 F-350 4x4 Outlaw
edge juice w/ attitude
MBRP 4" exhaust
6" fabtech on 37" MTs
1983 Porsche 944
white 5-speed
1979 mustang cobra
4.6 32V teksid
road racer/ street car
2001 GSX-R 1000
7t9cobra is offline
post #2 of 10 Old 06-20-2011, 11:21 AM
greenbeast's Avatar
Could be IPR o-rings. How many miles are on the truck? Injector o-rings could also cause a problem. Does it smoke at idle after it warm? Is it a chugg chugg then dies, or just cuts off?
97 F-250 350/200 Hybrids, Intercooled, Irate S468 T-4 Turbo, Irate comp Fuel system, BTS Twin pumps, BTS trans,
STOCK RODS
greenbeast is offline
post #3 of 10 Old 06-20-2011, 11:29 AM Thread Starter
No chugging no smoke. Just dies like you shut the key off
MBRP 4" exhaust
1983 Porsche 944
white 5-speed
1979 mustang cobra
4.6 32V teksid
2001 GSX-R 1000
7t9cobra is offline
post #4 of 10 Old 06-20-2011, 11:33 AM
greenbeast's Avatar
How many miles are on the truck? If it was me I would see how the IPR o-rings look. Will it start back up right away or do you have to wait?
STOCK RODS
post #5 of 10 Old 06-20-2011, 11:42 AM
Quoted: 50 Post(s)
In the interim period when it won't start, if you crank it, does the tach respond?
madpogue is offline
post #6 of 10 Old 06-20-2011, 12:00 PM Thread Starter
240k. Tach reads all the time. It wont start for atleast 20 minutes. Then it fires right off and drives great for a while
MBRP 4" exhaust
1983 Porsche 944
white 5-speed
1979 mustang cobra
4.6 32V teksid
2001 GSX-R 1000
7t9cobra is offline
post #7 of 10 Old 06-20-2011, 12:30 PM
greenbeast's Avatar
Is a sure bet its IPR o-rings or injectors. I would check the IPR o-rings first!!!
STOCK RODS
post #8 of 10 Old 06-20-2011, 06:21 PM Thread Starter
It dies like it's an electrical issue. it just dies. no warning, no sputtering or missing. Usually when something mechanical like that happens it will atleast give warning correct? also, if the IPR O-rings are shot won't it get a low injection pressure reading thus sending a code?
MBRP 4" exhaust
1983 Porsche 944
white 5-speed
1979 mustang cobra
4.6 32V teksid
2001 GSX-R 1000
7t9cobra is offline
post #9 of 10 Old 06-21-2011, 06:53 AM
greenbeast's Avatar
Not all the time, check the nut on the back of the IPR and make sure it is tight.
STOCK RODS
post #10 of 10 Old 07-04-2011, 12:46 PM Thread Starter
I replaced the o rings and the problem still exsists. However if I poor cold water on the ipr. Relay (if that's what it is) it fires right back up. So I need to order a new one
MBRP 4" exhaust
1983 Porsche 944
white 5-speed
1979 mustang cobra
4.6 32V teksid
2001 GSX-R 1000
7t9cobra is offline
