running hot - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-08-2011, 07:40 PM Thread Starter
running hot
Just picked up my first 95 f350 powerstroke with about 300,000 highway miles.On the dash the temp guage says NORMAL, this truck aways runs on the A area.You open the hood and you can tell the rig is hot.But it nevers goes higher and never boils over.Where do I start "electrial or cooling system."
rrgearsurplus is offline
post #2 of 6 Old 06-09-2011, 02:17 AM
Chop's Avatar
I would suggest replacing the temperture sending unit,it's located on the water pump.It feeds the signal to your gauge and it's less than 20 bucks.You can count on an accurate reading after this and maybe you aren't running hot
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
post #3 of 6 Old 06-09-2011, 10:49 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Mine never even touches the n, even after going on 22 hour road trips
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 6 Old 06-09-2011, 11:19 AM
Quoted: 84 Post(s)
Mine barely touches the O. I've noticed that the temp gauges are never consistent. I've been driving daily in over 100 degree weather too and it reads the same as always.
White95f250 is offline
post #5 of 6 Old 06-14-2011, 05:51 PM
deezelfromRofo's Avatar
@ the last 2 fellas, sounds like you both need to replace your thermostats. Sounds like they are stuck open. Had same thing with my temp gauge reading until I put a new one in.
97 ford f250 HD supercab xlt longbed
banks intercooler
banks power pack
285 75 16's
3" dp
DIY tymar intake 6637
stancor 586-902
B&W tow n stow
triple pillar gauges:
Banks Dynafact boost gauge
Banks Dynafact egt gauge
ISS Pro trans temp gauge
Hayden 32k transcooler
kittyless and unmuffled
deezelfromRofo is offline
post #6 of 6 Old 06-14-2011, 06:14 PM
Quoted: 84 Post(s)
Appreciate that, didn't even think of that as a possibility but if it's happened before with these things then it's probably happened to me.
