7.3 starting
How do you start a 7.3 ps. without a steering column, dash is still in truck.
Is there a work around I.E. what wires do you need energize to get truck to start i know to get it to turn over but not start,thanks |
Yes its easily possible. There is a white box that is bolted to the underneath of the steering column. It stays after the steering column is pulled and there is a knob on the white box that is accuated by the ignition tumbler... long story short, unbolt that white box from underneath the steerig column and you will see exactly what I mean.
Thanks for the info.,will go out check it out.
7.3 starting
Sorry no white box,must have gone with the steering column.
Ok, another question,how do engine builders start their engines on DYNO'S I have to assume when you turn key on it send power or a signal PCM. Then if that will not work then i will have to go wrecking yard and get box right.
jump the starter relay across the posts, it should turn over.
