loping at start up - Ford Powerstroke Diesel Forum
Old 05-11-2011, 08:22 AM
loping at start up
my truck is loping when i start it up. doesn't matter if i run 100 miles i can turn it off and start right back up and it will go to loping again. i can idle it up just a little and hold for a few seconds and it will stop. it's doesn't seem to be hurting anything just annoying and would like it to stop. any help/advice would be greatly appreciated. thanks
Old 05-11-2011, 08:29 AM
ADMIN AND TECH
an ipr can cause this issue , ive seen a couple trucks with the trans range sensor causing that also , just touch the gas and it will go away , are you getting any codes at all or have you had it checked
Old 05-11-2011, 08:41 AM
The ICP can do this to..
Old 05-11-2011, 01:37 PM
haven't had it checked yet, what is and where are the icp and ipr located @ and roughly how much do they normally run. and thank you for your input
Old 05-11-2011, 05:44 PM
Diesel Freak
mine loped too when i bought it but fuel additive cleared it right up within a couple tankfulls xdp lucas and diesel power supply have good ones
Old 05-11-2011, 07:29 PM
I run Lucas add. since I got the truck. It sat up for near 2 yrs. But was doing before parked according to previous owner. Lucas has aleady helped with fuel milage greatly
