whrool/humming noise under the hood - Ford Powerstroke Diesel Forum
Old 05-07-2011, 08:01 PM
I have a 97 f250 and I can some noise under the hood from the turbo maybe I have that one wire in front of the turbo disconnect and it still makes the noise
Old 05-08-2011, 12:29 AM
Feedback Score: 3 reviews
Video clip??
Old 05-08-2011, 08:46 AM
I don't know how to do the video clip but I can go more into details , I can hear it mainly when I take off and i can tell I lose some power like when I take off to get on the highway
Old 05-08-2011, 11:36 AM
Pull the intake boot off and see if there's a lot of play or broken fins
Old 05-10-2011, 03:04 PM
The turbo look good and how do you check the play I spun it and it turned easy. I took pictures of the turbo fins I will post them asap. I also have another question about the intake but I won't ask till I show you the pictures of them its easier to explain then.
Old 05-10-2011, 04:52 PM
turbo shaft play is checking the shaft in the turbo by grabbin the bolt and push and pull to see if the shaft moves in and out of the turbo alot or just a little
Old 05-10-2011, 06:32 PM
heres my turbo
heres my other question i have what is the tube in the intake?
closer
Old 05-10-2011, 06:48 PM
welll those last 2 pictures didnt save to my computer right can you see that tube thing im talking about in the 2nd picture
Old 05-10-2011, 08:31 PM
Crank case vent for oil fumes. you can delete it if you like to prevent your intake boots from getting soaked with oil. that orange intake boot and alum housing has to go. For has a TSB for the orange boots coming apart from oil soak down and then going through the turbo. How was the play?? any at all? There should be alot if any. And your fins look good.
Old 05-11-2011, 06:41 AM
I didn't check the play cause I didn't know how when I took it apart, but now I do I will try to do it soon. I did notice the oil in the in take , I assume that it was from that tube
