Motor issue
Got a 95 stroke been running great then start actin wierd when starting up. Now its really hard to start kinda acts like not gettin fuel but once ya get it goin it runs great. Any ideas ?
Maybe your fuel filter is clogged. Maybe your fuel system in the valley is losing pressure. Check in the valley by taking off the engine cover. Grab a good flashlight and look down the valley in between the valve covers. I don't know if your year had the machined hole drilled to drain valley leaks down to the flywheel housing... but look down between that valley... There are 3 blue fuel hoses that connect between the fuel bowl and the mechanical fuel pump. They might be bad. Or the banjo bolt in the fuel pump...that banjo bolt has 2 crush washers that might go bad... I dunno many things could be wrong. Fuel injectors might have a problem or perhaps your air filter is clogged up with crap... although I think you would've already checked that lol
Yea finally figure the problem out the other day. Ended up being the fuel pressure regulator
