motor wont start - Ford Powerstroke Diesel Forum
Old 04-23-2011, 09:56 AM
motor wont start
I have read alot of the threads and i can't figure out why i can't get mine to fire. i have a 1996 e350 with the 7.3 powerstroke. i have checked fuel pressure, fuses, fluid levels. i put new valve cover gaskets on with new wiring. please help i'm going to go crazy
Old 04-23-2011, 10:12 AM
does the wait to start light come on?
Old 04-23-2011, 10:15 AM
yes the light come on, it cranks fine, no smoke from exhaust
Old 04-23-2011, 10:18 AM
fuel pressure at 55?
HPOP res full?
Old 04-23-2011, 10:19 AM
where is the hpop located at
Old 04-23-2011, 10:30 AM
front of motor, top, dead center, you'll see a hex or square recessed drain plug on top. check there. should be full or 1" from top.
What was your fuel pressure?????
Old 04-23-2011, 10:54 AM
SCANNER,you need to hook one up and look at ipr duty cycles and also icp psi on cranking
Old 04-23-2011, 11:35 AM
i agree, but i was assuming he didn't have one or access to one.
Old 04-23-2011, 01:04 PM
Infidel
Credit given to some individual who posted this on the web.
Craig
Old 04-25-2011, 10:05 AM
motor won't start up with starting fluid eitherl. i know that it is a big no no to use it but when i tried it it sounds like it wants to. what else could be the problem?
