Cam shaft lobe for fuel pump - Ford Powerstroke Diesel Forum
Old 04-18-2011, 12:50 PM
Does the cam shaft on a new body style block have the lobe for a mechanical fuel pump? I am not sure of the year of long block that I got but am not getting any fuel pressure. Pulled the freeze plug and installed a new mechanical pump. It will run on either, so all electrical should be fine I think. The new pump did have the plunger with it so if the lobe is there it should be pumping.
Old 04-20-2011, 05:13 PM
Electrical Ogre
A SD will not have the cam lobe from the factory.
Old 04-20-2011, 05:19 PM
say no to rolling coal
Superduties all have electric pumps.
