Fuel pressure 97 7.3 - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-14-2011, 10:07 PM Thread Starter
Was checking my fuel pressure on my 97 7.3 today anyway the way i understand the pressure is supposed to be between 40-60 psi my question is when i checked mine today it was bouncing between 50- 65 psi i believe the pressure is good but should the needle bounce so errratically? or do i have issues with the fuel system I'm having other issues with the truck throwing the check engine light but not a code kinda self teaching myself on repairing it myself by checking stuff i read on these forums any help would be appreciated
75 binder is offline
post #2 of 3 Old 04-15-2011, 01:17 AM
JSchuricht's Avatar
The OBS trucks use a mechanical fuel pump, so some jumping around is to be expected.
JSchuricht is offline
post #3 of 3 Old 04-15-2011, 09:29 PM
pmasterson's Avatar
The mechanical pump is activated by a cam lobe which makes it erratic on a gauge. Mine bounces crazily between 40 and 60 psi.
1995 F350 CCLB 4X4
TW tunes, GS gauges & Aeroforce Interceptor, 3" RSK w/SD springs
DIY 6637, 3" DP to straight exhaust, HPX Crossover,
16x10 AR rims, 315/75R-16 Goodyear Duratrac
pmasterson is offline
