Fuel leak
The hose on the right hand front side of the fuel filter housing is leaking. It's easy to reach the leaking end but where does the hose end ?
dumps to the bottom of the block its just the water drain valve no fuel should come out once you turn it off( which is the postition its in)
this lines is the water drain valves and goes to the bottom of the fron of the engine to a metal pipe line that goes down the engine i will take a pic to show you where it go
A picture would be nice.
yes of course byddy i will do it soon as possible i was having a lot of work
jejejejejeje |
Looks like your fuel drain hose. When you flip the black lever to dump water out of the fuel bowl, that's where it goes and it just goes down and dumps onto the ground toward the front of the engine. If yours is leaking in the off position, the seal on that lever can go bad and is a pretty simple replacement.
in few moments i will post the pictures to these firend who need a professional help !!
heres is the pics you ask for it hope were helpfull
Thanks a lot guys
