Have a 1994.5 with a slight mis at 1200 rpm or less.
336,000 km (208,000 miles) No exhaust smoke after 3 or 4 seconds when cold, no smoke when warm. Starts and drives fine, except the slight mis idling and engaging the clutch from stop. Autoenginuity displays DTC tab = P1111 System Pass KOEO tab = P1298 IDM failure KOER tab = P1298 IDM failure Injector Buzz = P1298 IDM failure Contribution Test = P0269 -Cylinder 3 contribution/balance fault So is the IDM going bad or is the P0269 fooling the PCM into beliving the IDM is bad? Do i have 2 problems? |
Nope bad IDM Take it out and shake it to see if there is water present. When you get a IDM code it means IDM nothing else I recomend One from Swamps
Would you replace the idm before changing #3 injector? Could the injector be OK and just the idm goofy on #3
Thanks |
Yes sir If you get a IDM Code IT is always the IDM. You might have an issue with the injector but you must fix the problem with the IDM first.
Have a rebuilt IDM arriving next week.
Could a tired dual mass flywheel cause a failed Contribution Test = P0269? |
Installed the rebuilt IDM from Auto Computer Exchange, today, replacing the old 100A with a 110. This solved the DTC P1298.
Did not notice any change in motor or drivability. AE still displays Contribution Test = P0269 - Cylinder 3 contribution/balance fault. So next on the list is changing #3 injector. |
I have a injector if you need it.
do you still have a DMFW??
I'm new... What is a DFMW?
Dual mass flywheel?
