fuel leak 1997 7.3 - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-23-2011, 04:42 PM Thread Starter
1992_yota's Avatar
fuel leak 1997 7.3
my valley was full of fuel when i got home today dried it up and started my truck, its leaking out the bottom side of the fuel filter housing right at the shut off valve but more inward from the drain hose. would this be the shut off leaking or do they have some kind of seals on the bottom? just trying to get a idea before i tear it apart tomorrow. thanks
Jamie Davis
2001 F250 7.3 ext. cab short bed ZF6 lariat. - Riff Raff intake, Bully dog GT, 4in turbo back straight pipe, NcHornet CCV, 315/75/16 toyo mts stock lariats, . . .
1992 toyota pickup 4x4
1983 toyota pickup 4x4 -just a toy
sold
2000 f250 7.3 reg. cab 4x4 6 speed lifted 8inches 37s
1997 F250 4x4 7.3 5 speed cc/sb
1987 mustang coupe 5.0 lots of goodies
1992_yota is offline
post #2 of 8 Old 03-23-2011, 04:58 PM
Mikey's250's Avatar
I would say its the drain valve orings.
Michael- Georgia Powerstroke Diesel Association
2002 F-250 ECSB 4X4 Lariat
Mikey's250 is offline
post #3 of 8 Old 03-23-2011, 06:26 PM Thread Starter
1992_yota's Avatar
thats what i was kinda thinking, but wasnt sure. i changed one on a truck one time it just dripped. mine is spraying fuel out with pressure.
Jamie Davis
sold
post #4 of 8 Old 03-23-2011, 07:46 PM
r_jacksondiesel's Avatar
Location: Sunshine Coast or Baja California...Depends on the temperatiure
I had a hole in my fuel bowl in that exact same spot. Corroded through I think.
r_jacksondiesel is offline
post #5 of 8 Old 03-24-2011, 04:16 PM Thread Starter
1992_yota's Avatar
well i pulled it apart i have a hole bout the size of a tooth pic
Jamie Davis
sold
post #6 of 8 Old 03-24-2011, 04:23 PM
Adam-Arc's Avatar
JB Weld
97 F350 CC 4x4 Auto Welding Rig
Steamfitters Local 475, Newark, NJ
IDM mod/Homemade CCV/10k/6637/3"dp/4" exhaust/no cat/muffler
Adam-Arc is offline
post #7 of 8 Old 03-24-2011, 05:33 PM
Did JB weld work for you? I figured the guy I just bought it from probably did that to sell it. It happened a week after I bought the thing. After it happened I figured that the valley of the engine was too clean to be true! Just another tip to the OP, I tried to save money and ordered a new fuel filter housing from an international dealer instead of Ford. It looked like I would save $200 doing that. But when the one came from international it was the same casting, but had the pipes in different places. I used one from a wrecker.
JB weld huh? Amazing stuff, I've used it on 1200 hp Cat 3512 engines to repair pitting on the deck of the block with succes.
post #8 of 8 Old 03-26-2011, 02:00 PM Thread Starter
1992_yota's Avatar
i thought bout jb weld but i want to make sure it dnt happen again
Jamie Davis
sold
