no start - Ford Powerstroke Diesel Forum
Old 03-16-2011, 09:04 AM
no start
i just got a 94 1/2 and drove it home. i let it sit for a month and half went to start it and the batteries where dead so i replaced them and the cam sensor and it still wont start it just spin and spins
Old 03-16-2011, 10:25 AM
are you getting a wait to start light or smoke out the exhaust?
Old 03-16-2011, 07:17 PM
no smoke at all and i am getting the wait to start light i think the pcm is not letting it get any fuel
Old 03-17-2011, 11:12 AM
Full A-Team Member
94 1/2? check the oil level in HPOP, pre-96 had a drainback issue
Old 03-18-2011, 08:01 AM
ok check hpop and top it off for good luck check it after trying to start it looked fine but it still won't start
Old 03-23-2011, 07:22 PM
i also notice after trying to start truck that fuel will leak from the filter cap
Old 03-24-2011, 04:05 AM
Full A-Team Member
Put a new filter in and make sure it seals
Old 03-24-2011, 08:32 AM
it is a new filter it torqued down
Old 03-24-2011, 08:30 PM
is there any way to check the ipr with a volt meter to see if its reading anything during starting
Old 03-29-2011, 07:08 AM
ok i had some else start the truck i can't hear the injectors clicking would that be a electric problem or a oil pressure problem
