8 Leaking Injectors? - Ford Powerstroke Diesel Forum
Old 01-17-2011, 12:11 PM
I recently did the o ring job on my injectors because I had oil in my fuel and had some whit smoke. After replacing the orings it ran good, and barely smoked. Not it slowly started smoking more and more. I get a check engine light after awhile and it runs like crap plus won't restart when warm. HPO leakdown is what i figured. Replaced IPR rings, HPOP was just tested fine. I pulled the valve covers and it looks like all 8 injectors are leaking around the bottom springs while running. I know oil comes from the spout but this looks like there leaking. This
is what I'm seeing in all 8. Can all 8 be a bad injector or install error?
Old 01-17-2011, 01:37 PM
Re-running the truck the oil isn't as much as the video.
Also I pulled the injector plugs to see if it changed the idle and each one did but this one the idle stayed pretty much the same.
Tags
hpo leakdown, injector leaking, oil leaking
