95 f250 ebpv problem? - Ford Powerstroke Diesel Forum
Old 01-16-2011, 09:15 PM
rws rws is offline
I have a 95 f250 and i think the ebpv is acting up. While it is high idling it will sound like a big rig jake braking. and when i'm driving down the road it feels like its coming on and robbing me of power. I think i have it disconnected (2 wire connecter at the front and slightly to the driver's side) is this the right connector? will it hurt my engine?
Old 01-17-2011, 08:26 AM
plug for mine was located right under the compressor side of the turbo...and has been unplugged for years...it would be fine to unplug it
Old 01-17-2011, 10:20 AM
rws rws is offline
Thanks for the info. the reason i am asking is because when i disconnect the plug it seems to run a bit different. More power but it seems to have more vibration at an idle a bit of a miss. Could i be looking at a boost sensor or is the ebpv the only connector there?
Old 01-17-2011, 10:23 AM
to my knowledge the EBPV is the only plug on the turbo...
Old 01-17-2011, 10:32 AM
Is the sensor you connected on the front of the motor and in the driver side head?
I may be wrong, but it kind of sounds like you unplugged the ICP?
Old 01-17-2011, 10:37 AM
rws rws is offline
That is possible, it was dark while i was looking at it i assumed the wire that was going to the plug went to the main harness i'll check it out after work thanks
Old 01-17-2011, 10:44 AM
The one that should be unplugged mounts right to the turbo...should be somewhat underneath the compressor housing...i can go take a pic if you need one
Old 01-17-2011, 11:03 AM
rws rws is offline
That would be greatly appreciated. Like i said i am pretty sure i had the right one but it's possible i was wrong. I just don't want to screw something up and have to buy a new engine
Old 01-17-2011, 11:07 AM
http://cgi.ebay.com/ebaymotors/Garre...item2c589c9fcc
here is a pic of the plug from a turbo on ebay...only plug there on the turbo assembly
Old 01-17-2011, 12:07 PM
rws rws is offline
Thanks looks like i managed to get the right connector. Maybe its staying on more than i thought and when i disconnect it it is making more difference than i thought it would
