Hella oil leak! IDKWTS - Ford Powerstroke Diesel Forum
Old 01-11-2011, 03:29 PM
I have an epic oil leak on the driver side in proxcemity to oil filter. The filter is tight and seems to be coming from above it. I've lost around gal. of oil in the last month or so. I'm worried to drive it, due to fear of catastrophic failure. I'm down for any advise. Thanks dudes
Old 01-11-2011, 03:31 PM
mine does this, not a gallon but it's a combo of two things, my oil cooler and my turbo pedistal. and the rear corner of my VC
Old 01-11-2011, 03:39 PM
My leak isn't higher than the exhast manifold. The oil goes from mid engine to past the bellhousing and all over the driveway.
Old 01-11-2011, 04:09 PM
is the large tube under the axhaust manifold leaking at the ends? thats your oil cooler
Old 01-11-2011, 04:26 PM
What kind of a project am I in for? Found the gaskets and O-rings for Fifty bones.
Old 01-11-2011, 04:44 PM
not too bad.
look here: Oil Cooler O-ring replacement R and R - PowerStrokeNation
Old 01-11-2011, 04:56 PM
Thanks for the link bro. It looks to be a big enough painus in the anus to be a good time.
Old 01-11-2011, 05:02 PM
its not too bad really, just take your time, keep everything clean. Clean only the outside of the cooler, dont try to clean the inside. You'll regret that one if you do lol. and be sure to get all the gasket off the block and cooler ends, you'll regret that one too if you dont
