Help: fuel in oil!!! - Ford Powerstroke Diesel Forum
Old 01-10-2011, 11:59 AM
OK I have more fuel in the oil pan than oil right now. Where do I start? Toasted o-ring? Bad injector? etc etc. Just looking for some opinions on what to start looking into. Looks like a 12v swap may be in the near future.....
Old 01-10-2011, 12:19 PM
long shot but: is it possible its the fuel pump? If the diaphram cracked wouldnt it be possible is allowing fuel down into the crankcase? I just cant see it being an injector as it was running just fine until i went to start it on sunday.....
Old 01-10-2011, 01:23 PM
I have access to a super cheap NBS 7.3 motor, but I has a bend rocker arm, needs an oil pan and some small other things. Isnt virtually everything internally compatible between the two? same blocks right? IIRC the only differences are rods, turbo/piping, I/C, and HPOP right?
Old 01-10-2011, 01:27 PM
duct tape & zip ties
You could have a bad injector cup. If you are getting that much fuel in your oil. Or you have a a crack in the cylinder head and it is leaking fuel into the engine. Or you have bad O-ring on one of your injectors.
Old 01-10-2011, 06:44 PM
so if it is an injector problem, wouldnt I still have to have a problem with a piston/o-ring? Otherwise how would fuel be reaching the crank case? Is one problem more likely than another? thanks
Old 01-10-2011, 07:11 PM
it was the injector cups on a buddy's 7.3...
Old 01-11-2011, 04:53 AM
dumb question but what exactly are the injector "cups". I have done my own injectors a few times already so is this something I would be able to do myself?
Old 01-11-2011, 05:10 AM
If I remember correctly. When you pull out the injector look down into the hole that the injector just came out of. You will see it. Its thin and hold the injector. Should have a small hole at the very bottom of it. I don't know if you can get them out with out damageing them Some one will chime in in a few.
Old 01-11-2011, 05:13 AM
This might help you a little
replacing injector cups
Old 01-11-2011, 05:18 AM
cool thanks bud
