water in fuel light????
ok i have a curve ball for you all............ so might water in fuel light comes on when i accelerate........... but when im driving it doesn't. as soon as i step into it the light flickers.... soooooo and ideas
Do you have a filterbowl still?
i dont have a bowl..... i have an air dog
That's what I was thinkin...
Tuning/PCM issue, unless the harness to the sensor is shorting or something. |
well i have a fresh PCM im the mail thanks to bill. and i will chace down the wiring in the morning. why do you think its a PCM issue
Improper tuning / bad connections with the PCM will kick lights for no reason. WIF and WTS are the most common.
Usually thought there's other quirky crap associated with it. |
And aren't you running manual tunes on an auto PCM?
no i have a manual PCM in the truck. but why is it only coming on while im accelerating?
and it only flickers |
I'd guess short.
It's a common ish issue with E99's, and usually associated with something in the chips tuning not liking the PCM code it's mated to. Only reason I'm throwing out the PCM / tuning thing. |
well i have never had this problem with tony's tunes
