SOMEONE PLEASE HELP ME!!!!!! - Ford Powerstroke Diesel Forum
Old 01-08-2011, 03:11 PM
i just bought a 95 f250 4x4 5 spd powerstroke and it blows alot of white smoke when its cold witch i believe is normal and the issue i am having is the cel light will come on for 5 minutes or so ad the truck will spit and spuddler and will no turn above 2000 in any gear.
Old 01-08-2011, 03:47 PM
Feedback Score: 3 reviews
Run codes. Is it only on start up or while your running down the road? Does it crank slow or fast?
Old 01-08-2011, 04:19 PM
it only has done it a few times wass dring down the road at 30 or so and it turn the light on and would not rev above 2000 then turn the truck off and started it again and the light was not on and it seemed fine
Old 01-08-2011, 09:29 PM
does it just to rev over 2000 or does it stumble??
Old 01-09-2011, 07:41 AM
when it does it it wont run above 2000 rpms and spits and spudders and acts like it has no power at all
Old 01-09-2011, 08:36 AM
If this is happening mostly when cold try unplugging the ebpv. It could be stuck closed causing your grief.
Old 01-09-2011, 09:12 AM
where it that located sorry i am new to the diesel stuff and what is it
Old 01-09-2011, 02:28 PM
its a butterfly that closes off the exhaust to keep the heat in to warm the engine up faster. I gets old and doesnt work right the pigtail is located on the bottom of the turbo intake its a two prong connector i was gonna say that but Mutley beat me to it lol
Old 01-09-2011, 03:10 PM
now what it is doing is the check engine light is coming on and the truck is dying almost instandly but turn the key off ad restart it and it runs just fine??
Old 01-09-2011, 03:13 PM
Could be fuel pump going out or bad fuel filter. Have you checked the codes, fuel PSI or filter?
