i think i have a bad injector or bad orings please help
upon morning start up i get a huge clowd of white smoke doesn't matter what the outside temp is
i have noticed a huge loss or fuel mileage even after the truck is warm there is still a puff of white smoke i haven't noticed a loss of power when the engine is running over 2k i can hear the knock when the cruise is set going down the highway it doesnt run smooth it has a light knock its really hard starting if i dont plug it in over night i ran a buzz test every one sounded the same i ran cutouts every one sounded the same i am not using any coolant how do i find my issue i need help and i need to fix this fast unfortunately i need to sell the truck due to financial issues please help mods are in my sig thanks |
Sounds like the HPOP might be going bad?
How do I diag this, wouldn't that throw codes, the only inactive codes I have are for ebpv which I forgot to mention is gutted
Plug in a computer that can read the icp or plumb in a mechanical gauge on the passenger side oil rail and see what it says
i just checked icp (v) just after startup not warmed up yet it bounces between .91 and 1.02. or do i need to warm it up and check it
idk what the voltage means, needs to be psi
435-445 psi I also forgot to mention about a week ago when it was bout -10 plus a strong head wind I went to start it ran the glow plugs twice and waited about a min I heard a pop pop threw the exaust so I still think its a fuel issue but my ears are open
__________________ How did you check it and get psi i am learning I think I am loosing my hpop but I cant get it to a comp. till next week just hoping you are reading it with a meter thanks |
I have an older snapon code reader/diag tools
435 is low if thats at idle?
