96 PSD at idle........HELP
Just joined the Forum. I have 96 PSD w. 195k and 0 mods as of yet. So the problem is.... when im coming to a stop or just idling through a parking lot or rolling to a stop sign, the engine will just shut down on me. No spitting, or sputtering. Its almost like I just hit a fuel shut off. Its very sparatic, but is becoming more and more common. I just changed the fuel filter and air filter, but no change. The thruck will sit there all day and idle w.out a problem, but only when im rolling to a stop (in gear) does it just shut down. Was wondering if someone has had the same issues, or if I could get pointed in the right direction that would be awsome. Thanks.
Justin |
Check the fuel pressure regulator screen.
mine does the same thing, I changed the cam sensor and that seemes to fix the problem. scan the computer and you should get a code for that sensor if not try the screen,
Thanks for the help guys. Gonna try both this wknd.
check your IPR too. There is a large nut on the back of it. If it comes loose or falls off it will make the truck just shut off. I had a similar prob and it turned out the nut had come loose and fell off.
What is the IPR and where is it located?
Injector pressure Regulator, regulates the high pressure oil that powers the injectors located ( sitting in the truck) left of the HPOP. Has a two pin connector
