bad ignition??
so ive replaced my starter relay on the fender a couple time and it still will not start half the time and i have to use a screwdriver to cross the posts on the relay to get it to start. so im thinking its the ignition?? (what else coult it be
)so for all you guys and for some reason love wiring where do i go from now. im thinking about putting a push button start on thanks a lot |
If you cant find out what it is or cant afford to fix it, I have used a push start button on my old truck... It is easy and cheap!
thats what im leaning towards, what do i need to do?
when I did mine I just bought a couple feet of red and black wire, some electrical connectors and then the push button switch. You can get the push button switch at any auto store.
I connected the wires to opposite sides of the sylinoid / relay and then ran them through to the cab and connected the switch. You will have to turn the key to the on position and then just hit the button! |
ok sounds good. so go from each side or the starter realay? hot dog ill be back to starting the truck from INSIDE of the truck.
Thats right.... just like crossing the points with a screwdriver to start it, except using the 2 wires and a switch so you can do it in the truck.
