5mm Allen Wrench End Stuck in Glow Plug Hole
Okay, I switched-out my injectors today and was replacing the oil diverters using a 5 mm allen head on the end of a driver. Well you guessed it, the small allen head came out and went right down into the open glow plug hole. I tried fishing it out with a magnet, but the magnet is not strong enough -- it's probably lightly wedged in there.
So, should I hand crank the engine using a wrench, in hopes that the compression will blow it out? or do I need to remove the head -- ugh! Rather not do that. |
ok that makes more sense. i was wondering why in the hell would you drop that in there! i dont thing compression will blow it out. can you see it? thy to get a better magnet. other than that i dont know
deffinetly get the biggest magnet you can get in the hole!
Sometimes you can put another, more narrow, metal object onto your magnet and that will become magnetized as well. I've done that with a paperclip and a good magnet when cleaning out the shards of metal from an exhaust manifold after tapping it for a EGT probe.
or you can do something by tapping the pole on a battery, but i cannot remember...its how you can magnetize a screwdriver
Ah ha, got it. I used one of my wife's hardwood chopsticks and put a dab of crazy glue on it. Stuck it in the GP hole up against the allen head for 45 seconds and voila -- out comes the offending bit. I cringe to think of what that would have cost me if I couldn't remove it. Now just another 45 minutes of reinstalling pieces and parts and I should be cranking the life into new stage 1s -- that's happening tomorrow.
Thanks for all your suggestions. I really liked the ones that hinted at creating a magneto. I thought about that, but I couldn't think of how to power it. I thought about a framing nail, copper wire and a 9V battery, but the suggestion of using the truck's 12V battery was brilliant in its simplicity. |
