block heater problem - Ford Powerstroke Diesel Forum
Old 12-27-2010, 06:03 PM
i think my block heater might not be working because when i used to plug it in it would sound like there is something running now there is nothing. how do i test it and see.
Old 12-27-2010, 06:13 PM
put a DVOM on the end of the plug and read how many OHM's or resistance their is. An open circuit will not display anything.
Old 12-28-2010, 08:49 AM
i checked it out today and when i tested it nothing. what could be the problem the cord or heating element.
Old 12-28-2010, 08:59 AM
Have you got under there and felt the block? Warm? Cold? Does your dash temp gauge show any temp after it's been plugged in for a while?
Old 12-28-2010, 09:08 AM
When i used mine the cord and exstension cord felt warm to the touch after so many hours.Also when you hook it up you should see a small arc which means there is a draw.A simple test without special equipment.
Old 12-28-2010, 09:09 AM
its cold. and the temp gauge showes nothing
Old 12-28-2010, 09:11 AM
May need to replace the element in the block.
Old 12-28-2010, 10:06 AM
I just found one on ebay fits all ours 7.3 for around 67.00 dollars and it is a two piece,a cord and the element.If you decide to replace element,be ready to catch coolant.It looks as though you could remove cord and bench test and or repair if neccessary.Just a thought
