Little to no oil pressure while at idle - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-26-2010, 08:33 AM Thread Starter
DANA60F250's Avatar
I dont know if my sensor is getting bad or what. Truck starts fine runs fine and drives fine. Has 290,000 on the engine. When the truck idles it reads no oil pressure. i changed the oil and added lucas oil additive and it got better, but now it twitches between no pressure and normal reading. Anyone got any ideas.
DANA60F250 is offline
post #2 of 7 Old 12-26-2010, 08:36 AM
hook up a mechanical gauge to the hpop reservoir somewhere.
2008 6.4 f250 lariat 4wd
melmount is offline
post #3 of 7 Old 12-26-2010, 07:01 PM
bondsman's Avatar
The sending unit is on the hpop reservoir. It has a single wire going to it. Clean up that connection and give it a go. Also as mentioned, slap a mechanical gauge on the hpop reservoir so you can compare the actual to the dash.
05 F250 4x4 CC, 9.5" Rize/Icon, 38" Toyos, 20x12 Pacers, 5" MBRP, AFE stage 2, Cass 190s, Powermax, ELC w/filter, RCD EGR delete
04 Excursion 4x4, vacation bus
Project 1979 F250 6.0 powered in progress
bondsman is offline
post #4 of 7 Old 12-26-2010, 07:55 PM
ryandamo's Avatar
that guage is only an idiot light, it doesnt show actual oil pressure, if its below a certain level, it goes to zero and if its above it, it goes to normal, the sender probably went bad, remember the injectors need oil to fire, if it wasn't building any, the truck wouldn't run
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #5 of 7 Old 12-29-2010, 04:38 AM
waljon's Avatar
Take your oil filter off and look up inside there to the right there is a little hole with a disc ,washer, and spring if it is not there than that is your problem on the early trucks this disk is held in by just being staked in on the newer trucks it has a snap ring, this is an oil bypass.
waljon is offline
post #6 of 7 Old 12-29-2010, 04:53 AM
if that bypass was open, wouldn't it just not go thru the filter? Would still have pressure wouldn't it?
melmount is offline
post #7 of 7 Old 12-29-2010, 02:42 PM
waljon's Avatar
It would have enough pressure to run the truck, On the gauge it would read Zero at Idle, and raise with RPM.
I agree with you though that a real mechanical gauge should be installed to see actual pressures
waljon is offline
