NEED HELP WITH A OIL LEAK AT FILTER HOUSING - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-18-2010, 01:48 PM Thread Starter
I THINK THE THING IN FRONT OF MY OIL FILTER IS THE OIL COOLER. IM NOT SURE. I DO KNOW THAT AT TIMES IT IS LEAKING . DOES ANYONE KNOW IF YOU CAN FIX THIS AND THE PART NUMBERS FOR KIT. THANKS MY TRUCK IS 97 F350
car23 is offline
post #2 of 3 Old 12-18-2010, 02:20 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
yeah there are o rings that can go bad, the o rings that connect it to the block i believe
Trucks and parts............
kanuck15 is offline
post #3 of 3 Old 12-18-2010, 06:04 PM
bondsman's Avatar
That is the oil cooler. There are 4 large orings in there and a metal gasket at each end between the endcaps and the block. You will need to remove it, pull the endcaps off, clean it all up, replace the 4 orings, put it all back together, install it back on the motor with the new gaskets. Very common oil leak on the 7.3l
05 F250 4x4 CC, 9.5" Rize/Icon, 38" Toyos, 20x12 Pacers, 5" MBRP, AFE stage 2, Cass 190s, Powermax, ELC w/filter, RCD EGR delete
04 Excursion 4x4, vacation bus
Project 1979 F250 6.0 powered in progress
bondsman is offline
