1995 powerstroke wont even crank - Ford Powerstroke Diesel Forum
Old 12-07-2010, 11:45 AM
Exclamation 1995 powerstroke wont even crank
Hi i need any help fast so far ive replaced the following glow plug relay, starter relay, most relay fuses, had the starter tested and it passed and replaced cam relay! PLEASE HELP thanks!
Old 12-07-2010, 12:14 PM
drives a ranger
Send a message via AIM to kanuck15
Sounds like either a bad ground OR a bad signal wire to the starter solenoid (the one on the starter) id try running a 14 gauge wire from the battery down to the starter solenoid and seeing if it kicks over. ive had that wire go bad a before
Old 12-07-2010, 01:45 PM
so what do you think i should try to do first?
Old 12-07-2010, 01:46 PM
drives a ranger
id check the grounds first, then go to that wire
