Trucxk died going down the road - Ford Powerstroke Diesel Forum
Old 12-05-2010, 03:05 AM
Need help please. 97 F350 started fine this morning and went down the road fine, then just up and died. It will crank but just wont fire off. Tell me where to start, SNOW IS COMMING.
Old 12-05-2010, 04:32 AM
After some research I guess I figured out it is prob the CPS. No smoke and gauges aren't moving while cranking. But how the hell am I suposed to get my arm in there to get the thing pulled out.
Old 12-05-2010, 08:11 AM
It is possible. The last one I changed was in there so tight, I had to take a small pry-bar to pop it loose (after it was unplugged and unbolted, of course).
Old 12-05-2010, 02:33 PM
Got it replaced and didn't fix the problem. I was about to loose my mine and decided to look at the fueses. I found fuse #22 was blown. I replaced it and she started just fine. I'm woundering if there is a bigger issue that made the fuse blow.
Old 12-05-2010, 03:16 PM
Good job! Carry a spare fuse or two, if it continues then diagnose.
Grey CPS or black? I carry a spare CPS too.
Old 12-05-2010, 03:18 PM
Other guys with that fuse blown have had electrical in numerous places off main wireing harness. Look for frade or melted wires.
Old 12-05-2010, 04:30 PM
Got it replaced and didn't fix the problem...
Congrats on finding the blown fuse. And now you have a spare CPS. Two reasons to celebrate.
Might be fuel heater short too, as I understand it.
Old 12-06-2010, 04:01 AM
It was a grey cps. I've got to put some miles on the truck today, the snow is adding up. Hope it stays running.
Old 12-06-2010, 04:45 AM
Well I was feeling good this morning until I went out to start the truck. Found the same fuse #22 was blown. Where do I start now?
Old 12-06-2010, 05:10 AM
try that fuel heater thing, also check for chaffing of wires on top of engine
