Yet Another NON running problem - Ford Powerstroke Diesel Forum
post #1 of 24 Old 12-02-2010, 05:12 PM Thread Starter
Question Yet Another NON running problem
I have a 94 F250 4X4 Manual 7.3l Truck has 210k. I am a mechanic in the Army for 16 years now. I have exp, but am not sure after checking what I know to check.
Initial problem was would stop running while driving. No electric fuel pump so tapped on manual pump and truck would start up and run fine, for a little while.
Replaced fuel pump(not my first time). Would not start.
started blowing #22 fuse. Through reading the forum, replaced GPR, still blew fuse.
Disconnected wire at fuel filter fuel heater. Stopped blowing fuse.
Wait to start light comes on and goes off after a few seconds.
Truck cranks fine but no smoke and no hint of starting.
When replacing pump, broke i think it is called the ICP, boght new one and replaced. still not starting up.
Checked Fuel filter for fuel and fuel reaches the top of filter.
What should I check next ???
joeskisnow is offline
post #2 of 24 Old 12-02-2010, 05:17 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
check your wiring going to the injectors, also check the IDM (injector driver module) and the the IPR (injector pressure regulator). Could also be PCM
Trucks and parts............
kanuck15 is offline
post #3 of 24 Old 12-02-2010, 05:51 PM
your rpm gauge move while cranking the engine over? If not then its your cps.
94 psd is offline
post #4 of 24 Old 12-02-2010, 07:58 PM Thread Starter
Not Sure
Have not looked at the tach, the oil pressure moves while cranking !!
post #5 of 24 Old 12-02-2010, 08:00 PM
kanuck15's Avatar
Quoted: 10 Post(s)
haha well oil pressure is a good thing
kanuck15 is offline
post #6 of 24 Old 12-02-2010, 08:19 PM Thread Starter
YES
Yes oil pressure is a good thing !!! I have been swamped at work all week, will be able to takle this problem Sat and Sun !!
Thank you for all of the feed back !!!
post #7 of 24 Old 12-02-2010, 08:33 PM
97_stroke's Avatar
Is this an IDI 7.3 or a "Powerstroke" 7.3?
97' F-250 extended cab 5-spd, 4" AFE exhaust, Tymar cold air intake, guages, Modified IDM, Stage 2 injectors, Complete fuel system, TS 6 pos. chip, Southbend Con OFE clutch, D66 turbo - Gone
08' F-250 CCSB, Spartan 275 tuned, exhaust, S&B CAI - Gone (miss it)
2007 -duramax (who cares)- Gone!
2002 -F-350 CCLB - Gone
2013 - F350 CCSB 6.7 Here!
97_stroke is offline
post #8 of 24 Old 12-02-2010, 08:35 PM
kanuck15's Avatar
Quoted: 10 Post(s)
its a psd, idi didnt have 22 fuse or a fuel bowl in that respect
kanuck15 is offline
post #9 of 24 Old 12-02-2010, 08:35 PM Thread Starter
PowerStroke
It is a PowerStroke !
post #10 of 24 Old 12-02-2010, 08:44 PM
97_stroke's Avatar
Make sure you have good ground cables and connections from your batteries.
