Dash battery light is on - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-28-2010, 09:23 AM Thread Starter
sgt dave's Avatar
Quoted: 3 Post(s)
Just replaced both batteries last week with two optima red tops and since then the in dash battery symbol has lit up. It doesn't stay on constant but will flash intermittently. Thanks for any advice.
1996 F250 SC/LB, 4x4 PSD, ATS stage 1 trans 5 star tcc, AC codes,TW tunes, magnaflow 4" exhaust, 6637 , FS 2500 bypass oil filter,pure power reusable oil filter, isspro gauges, dieselsite cpr fuel pump system, adrenaline hpop, pml rear diff cover ,ebpv delete,non epbv pedestal, king pin dana 60, swamps idm, tru cool 4739
USMC 1993-1998
Plumbers & Pipefitters L.U.447
sgt dave is offline
post #2 of 6 Old 11-28-2010, 11:11 AM
JSchuricht's Avatar
First thing I would check is to see if the terminals are tight. Next, check both batteries individually to see if one has an issue. Finally, check the voltage with the truck running. You should see 13.5-14.5v, don't rely on the meter in the cluster. If the voltage is much lower than 13.5 and the glow plugs have had a chance to shut off, you have a alternator issue.
JSchuricht is offline
post #3 of 6 Old 11-28-2010, 11:45 AM Thread Starter
sgt dave's Avatar
Quoted: 3 Post(s)
Thanks, I'll check it out next week. I'm home right now in California and the truck is in Indiana, been working there for two months
USMC 1993-1998
sgt dave is offline
post #4 of 6 Old 11-28-2010, 11:50 AM
dieselburner21's Avatar
Quoted: 8 Post(s)
Check the alternator...I run redtop optimas and when mine did that alternator was fried I wouldnt run around to much with it doing that mine died in the middle of an intersection
Will
2010 FORD F250 LARIAT CCSB 6.4
-H&S Mini Maxx / Edge Insight CTS / 4" Flo Pro Dump / 20" Fuel Hostages / 33" Toyo AT's / Airdog II 4G
2006 FORD F250 LARIAT CCSB 6.0 - TRADED
2000 FORD F250 LARIAT CCSB 7.3 - SOLD
dieselburner21 is offline
post #5 of 6 Old 11-28-2010, 07:45 PM Thread Starter
sgt dave's Avatar
Quoted: 3 Post(s)
I'm working in Edwardsport and staying in Sullivan right now
USMC 1993-1998
sgt dave is offline
post #6 of 6 Old 11-28-2010, 09:07 PM
444 ci's Avatar
mine was doing the same thing changed alternator no more light.
444 ci is offline
