Need help!! Possibly bad injector(s)? - Ford Powerstroke Diesel Forum
post #1 of 35 Old 11-24-2010, 03:14 PM Thread Starter
This problem just started. So far only happens when the truck sits overnight. I goto crank it up, engine will sputter like it almost starting. Turn key off, ign back on, wait to start light is out...turn key start, sputters a little bit and fires up...plume of blk/gry smoke comes out the exhaust! I'm thinking leaking injector.
Info:
96 5sp
157k with original injectors
mods put on at 153k:
tymar intake
4" turbo back mbrp
TW 6 pos chip
I drive in eco mode 99% of the time. I do not rump on this truck what so ever. I would like to order the injectors tonight, if thats the issue.
Traded in:
96 F250 Supercab 4x4 5spd
FMIC
4" MBRP turbo back
Baby Swamps
D3UC3S is offline
post #2 of 35 Old 11-27-2010, 02:13 PM
countryraised's Avatar
more likely leaking injector o-rings than the injectors, is the truck using any oil?
Vince
John Deere product developement
FOR SALE '99F350 2008 F350 mini maxx'd
countryraised is offline
post #3 of 35 Old 11-27-2010, 05:11 PM
Feedback Score: 3 reviews
Dido^^^^^^^^^
96F350KID is offline
post #4 of 35 Old 11-27-2010, 05:43 PM Thread Starter
Yea, not to much tho. I also have a rear main seal leak. I did a "buzz" test, all the relays were clicking over. Is the oring itself replaceable? I'm new to diesels, is there a way I can ck to see which cylinder the injector is leaking?
Right now I have the valve covers off, changed fuel filter and syphoned the hpop 1qt and put new rotella T in that...that oil was nasty!
Traded in:
FMIC
4" MBRP turbo back
Baby Swamps
D3UC3S is offline
post #5 of 35 Old 11-27-2010, 08:45 PM
Yes they are like 10 dollars an injector from for you have to pull the injectors out to do them if you pull to check them you might as well replace them
post #6 of 35 Old 11-28-2010, 12:00 AM Thread Starter
From? What do I need to buy? I bought injectors last night, but I could cancel the order if there is a cheaper way then the $1200 I just paid!
Traded in:
FMIC
4" MBRP turbo back
Baby Swamps
D3UC3S is offline
post #7 of 35 Old 11-28-2010, 06:46 AM
Don't know much about Dorman, but $4.05 per injector:
DORMAN Part # 904206
Rockauto.com
Edit: Actually that looks like all the o-rings for the injector.
Brian
'96 F250 SC, 7.3, 4x4, E40D, and it's red... and white.
retmotor is offline
post #8 of 35 Old 11-28-2010, 10:23 AM Thread Starter
ORDERED! I hope this is the fix...thanks guys!
Traded in:
FMIC
4" MBRP turbo back
Baby Swamps
D3UC3S is offline
post #9 of 35 Old 11-28-2010, 03:40 PM
Let us know.
Brian
retmotor is offline
post #10 of 35 Old 11-28-2010, 04:39 PM
do you hear a clicking noise like the injectors dry firing? Most likely will occur when it sits overnight
