Need expert advice
Hey all... I have an ambulance in my fleet that seems to miss at an idle. I was told it had new injectors put in it right before I started here so I am at a loss as to where to go from here. you can feel a shake at idle and from the attached youtube link you can watch/hear it idle. Any suggestions would be awesome.
I had the same issue it was un even fuel pressure to each head, It was something in the fuel bowl when I installed the electric system it idles and purrs like a new truck. It may be the same issue or not start with a fuel filter, drain fuel bowl, and clean FPR screen
That might of been my post im not sure. the ICP?? if you unplug it when you have a low power issue and its restored is more then likely a ICP issue thats a sensor on the drivers head its a three wire connector. The FPR is under a brass 19mm bolt that is a whole unit attached to the right of the fuel bowl( looking at the engine) by three 10mm bolts. when you pull that off on the fuel bowl itself is a screen which when clouged causes a poor running condition. I can take pictures and post if you like of my other truck.
Sounds like ICP?
Its behind the A/C compressor on a truck i don't know if its diffrient on a van or Ambulance with dual alts. Its in the front on the head on top of it looking at the engine its left of the intake bracket that is on a truck. if you pull it out and their is oil on it replace it. Also a bad ipr or ipr o-rings could cause that too is the CEL light on? Did it loose power? Does it fall on its face? I'll get those pics posted tomorrow.
thanks for your help. I'll see if I can find that behind the compressor - next question if I unplug it and it runs better is it bad to run it with it unplugged until I get the part on it? Thanks |
It will run it will default the computer to think the Icps at 425PSI which will throw the tranny into limp mode aswell. Pull the plug and look for oil on the plug. Also if its dry you need to aquire a scan tool to check the data. Also the Ipr could cause a rough run/ no start condition. 3 sensors will make the truck run bad, ICP, IPR, Oil Temp sensor, Any fuel leak as tiny as can be will cause a bad running condition. Every truck I ever worked on never threw the tranny into limp mode. HOWEVER if you have a code for ICP or IPR it will do it in a way.
