Now 3 codes p0472, p0643, p1280 - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-10-2010, 07:11 AM Thread Starter
Truck lost power and idle real rough then shut off. Replaced bad fuel filter, cam sensor, icp sensor, oil and filter. Left filter loose and crank with plebty of diesel flow out of filter top. Used my superchips and found these codes. Do I need to disconnect battery to remove codes? I did get truck to start and run be terrible. Foot to floor and maybe 1000 rpm. Now what?
haywood is offline
post #2 of 3 Old 11-10-2010, 07:31 AM
Welderman2008's Avatar
0472 is the exhaust back pressure circuit....
1280 is icp circuit low....
and i couldnt find anything on the 0643
96 F-250 extd cab 4x4
6637 Filter
Unplugged (soon to be gutted) EBPV
Straight piped in to 6 in tip
Upcoming mods:
3in Downpipe, TW chip, Gauges, adrenaline HPOP, Electric Fuel, BTS trans, Stage 2's/3's Modded H2E
"When injustice becomes law, resistance becomes duty." -Thomas Jefferson
Welderman2008 is offline
post #3 of 3 Old 11-15-2010, 01:44 PM Thread Starter
OK swapped out cam sensor and icp sensor and would not start. Loosened fuel filter and cranked and no fuel flowing out of filter canister. Replaced fuel pump and truck now runs and drives normal. But now I have code p0221 which is throttle position sensor switch b circuitrange/perf. and will die but restarts right away. Did I put something on wrong. I double checked everything and is back in order I believe.
haywood is offline
