i am about to F*&$^n sell it!!!! - Ford Powerstroke Diesel Forum
Old 11-09-2010, 08:02 AM
Ok i have a 96 w about 220,xxx on the clock and i just bought AE cause my buddies 97 just leaves mine in the dust...so i plugged AE up thinking ok this is gonna lead me to my problem NOPE!!!! no codes buzz test and contribution test passed ebpv umplugged and wired open, smokes white alot if not plugged in now no start if not pluggged in even after its hot at wot it will smoke white and from 2300 on it has no power at all no boost leaks and it takes my oil pressure a few seconds of revving to make the needle move and my icp only registers between 50-150 psi while cranking......im at a loss if i cant figure it out soon i might buy a cummins.....jk guys jk id rather push my powerstroke lol...
Old 11-09-2010, 08:16 AM
I don't think the truck will fire at 150psi ICP. You need to figure out why your ICP is so low. Sounds like a good time to install a modded 17° HPOP.
Old 11-09-2010, 08:21 AM
ya i was thinking that or the ipr where can i get a 17 from n how much do they run?
Old 11-09-2010, 08:31 AM
I bought a used 17° pump out of the classifieds here for $150, then had it sent to Joey at Terminator Engineering for the mod. I sent Joey my 15° pump once I received the 17° and didn't pay a dime for the mod.
Old 11-09-2010, 12:22 PM
but im not throwin codes for low oil pressure so will that fix my problem?
Old 11-09-2010, 01:08 PM
At 150psi while cranking, something isn't right! I think you need 500 just to fire the injectors.
Old 11-09-2010, 05:49 PM
so could the ipr be the culprit? or would that throw a code?
Old 11-09-2010, 05:52 PM
so what did ya do again for your HPOP??
Old 11-09-2010, 06:04 PM
nothing its the stock hpop
