Tip of Glow plug Stuck in HEAD! Help - Ford Powerstroke Diesel Forum
Old 11-01-2010, 07:31 AM
Changing the glows plugs in my fathers '96 350.. and the Last glow I pulled... against the fire wall on pass side... well the tip of the glow stayed in the engine.
THere is something for me to grab onto, but it will not come out.
ANyone have this problem before... and if so, is there a cure without pullin the head off?
All and any help is encouraged.
THanx
Old 11-01-2010, 08:12 AM
there is a glow plug puller tool i have seen it before on here but i couldnt gind it. it is made for ur problem. im new here sorry i couldnt help more
Old 11-01-2010, 08:44 AM
check your pm
Old 11-01-2010, 09:45 AM
shop vac + small funnel
Old 11-01-2010, 10:33 AM
This is why aftermarket glow plugs are frowned on. I've heard of people breaking them off somehow and just letting the remains get spit out the exhaust.
Old 11-01-2010, 01:14 PM
Well no such luck. I tried the mini- visegrip slide puller... I oiled the h- outta of it.
The thing won't move a bit. It won't go in or out.
Can I just run it the way it is?
Clearly these are crappy glow plows... the are not the stock ones like I run in my truck.
Old 11-01-2010, 02:26 PM
Agh I thought the tip was in the cyl sorry. lol
Old 11-01-2010, 02:29 PM
fire the motor up and pop it out
Old 11-02-2010, 03:58 PM
A buddy of mine is a ford tech and when mine got stuck he told me to set a board over it and hit the key, it will pop out pretty fast so watch it.
you dont want to keep pulling on it or twisting it because if it breaks you gotta pull the head to get the lil pieces out.
