Starting problems.. - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-31-2010, 04:48 PM Thread Starter
cntryboy17's Avatar
Starting problems..
Truck takes 3-4 cranks to get started in the mornings. I have replaced the CPS and the gp relay is good what else should i check?
FB: Kyle Durflinger
E99 F350 CCSB 4x4, Auto, All stock for now..., straight piped
1990 f-250 7.3idi 4x4 5 speed
Originally Posted by oldtimer550 View Post
Chevrolet = French word for non-hetero buttsecks.
Originally Posted by 1tonpower View Post
the wait for the coverage articles in DP is like waiting for a girl to put out for the first time....
cntryboy17 is offline
post #2 of 7 Old 10-31-2010, 04:59 PM Thread Starter
cntryboy17's Avatar
Also smokes white while starting
FB: Kyle Durflinger
post #3 of 7 Old 11-01-2010, 12:36 PM
Get your batteries tested. They need alot of CCA to turn em over fast enough to build oil pressure. Check your cables also. I went through the same thing as you. Ended up been a week starter. Now the old trucks startes right up with out any hard cranking. It still blows some white smoke for a few minutes but soon stops.
bfr44 is offline
post #4 of 7 Old 11-01-2010, 12:41 PM
strokin95style's Avatar
How many miles? Could be a couple bad glow plugs. best ones to go with would be factory Motorcraft gp's.
Nater
1995 f-250 rclb
7.3~317k miles & countin
3" Downpipe
Superduty 10.5" 3 pinion Trac-Lok rear
Dana 60 s.a.s
1997 ccsb , 353,500 miles
5" lift on 315x75x16 cooper at3's.
Clear headlights, tinted tails, rear buckets,
Dana 60 swap, zf5 swap.
rosewood 180/100's, t500 hpop, php hydra, e fuel.
strokin95style is offline
post #5 of 7 Old 11-02-2010, 06:41 AM Thread Starter
cntryboy17's Avatar
has 276xxx miles
FB: Kyle Durflinger
post #6 of 7 Old 11-02-2010, 08:39 PM
id say glow plugs. i replaced mine at about 240k
Nater
1995 f-250 rclb
3" Downpipe
Dana 60 s.a.s
post #7 of 7 Old 11-03-2010, 08:14 AM
It could also be the injectors or the piston rings. My 97 stroker had the same issues. If some of the piston rings are bad then that means you wont acheive enough compression to fully combust the atomized fuel, hence the white smoke.
stroketech2011 is offline
