ROUGH IDLE NO POWER THEN SHUTS OFF AND WONT START UNTIL NEXT DAY AND SAME THING - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-31-2010, 04:14 PM Thread Starter
Used truck twice last week and no trouble. Sat. went to drive and started idleing rough then slowly the power went away and finally shut off. Would not restart and had to leave it over night. This morning changed fuel filter which was half way up plugged with rusty sludge. Fuel in filter housing looked good and housing was 1/2 full with fuel. Drain some fuel from tank and let it sit and it looked good. 179k stock with exhaust. Have had truck for 10 years and now first time trouble. Getting towed to house. Which way to turn now? What ive read on other threads appears to be idm. Other thoughts?
haywood is offline
post #2 of 8 Old 10-31-2010, 04:23 PM Thread Starter
Also no smoke from exhaust. Dripping Fuel leak on back side of passenger head has been there for a long time and now has increased almost to a dribble.
haywood is offline
post #3 of 8 Old 10-31-2010, 07:59 PM
Is the tachometer reading when you crank it?
sgg93 is offline
post #4 of 8 Old 11-02-2010, 07:47 PM Thread Starter
Yes tach does move when cranking. Maybe 25 RPM. Oil was 1 gallon low. Didnt have any new oil to put in and will top off tomorrow to see if it starts up. I will feel like a idiot if thats all it was.
haywood is offline
post #5 of 8 Old 11-03-2010, 07:35 AM Thread Starter
Used a Super chips programmer and found this. P0340 and P0604. The P0340 says camshaft position sensor but the tach does climb when crank but no start.
haywood is offline
post #6 of 8 Old 12-09-2010, 09:10 AM
I'm curious, whatever happened with this?
Brian
'96 F250 SC, 7.3, 4x4, E40D, and it's red... and white.
retmotor is offline
post #7 of 8 Old 12-09-2010, 10:03 AM Thread Starter
It ended up being fuel pump at first. I drove for one day after replacement then I had to replace 5 connector harness that goes around fuel filter cannister and under and connects to fuel heater and hpop. This harness when shook would make truck run terrible or shut off. Also my fuel that was getting really bad from passenger side head was nothing more then the old fuel pump leaking from the weep hole.
haywood is offline
post #8 of 8 Old 12-09-2010, 12:35 PM
Sometimes it's never just one thing, is it? Well, cool. Glad you diagnosed it and got it up and running.
Brian
retmotor is offline
