rough idle wants to die? - Ford Powerstroke Diesel Forum
Old 10-30-2010, 04:39 PM
hi guys i am new to the powerstoke world, i have a 1996 f250 4x4. after i have been driving it for a while it starts idleing like it has a cam in it or something. i hooked up my programer to it and it is throwing a couple dif codes. like my air intake temp and a couple others. im woundering if it could be the pcm. any bit of info would help me, i really dont want to take it to a mechanic lol thanks in advanced
Old 10-30-2010, 04:41 PM
what codes are you getting??
or if any of you are in crwfordsville in area maybe you can check it out and see what it is doing. thanks
Old 10-30-2010, 04:42 PM
Old 10-30-2010, 04:43 PM
i ment **1280**
Old 10-30-2010, 04:56 PM
p1212 and p1280 say that your ICP sensor is bad or dying. p0113 is air intake temp too high or signal short.
Old 10-30-2010, 05:04 PM
ICP sensor is fairly easily to change out. did mine a couple years back, bought one at the IH dealership.
Old 10-30-2010, 05:08 PM
wher is the icp sensor at? ill try replacing that and see if it helps. would the air intake make it rough?
Old 10-30-2010, 05:17 PM
behind the AC compressor. has 3 wires going into a purple looking connector.
Old 10-30-2010, 05:18 PM
it's screwed into the block.
