hpop draining back probems can u help? - Ford Powerstroke Diesel Forum
Old 10-29-2010, 05:29 PM
i really hope its not some o ring deep in the engine.i did the injector o rings but still have to fill the reservior manually for it to start it must be something small because it still runs reallly reallly good once i get it running
Old 10-29-2010, 05:31 PM
drives a ranger
Send a message via AIM to kanuck15
is there any oil leaks? if not it might be the check valve in the hpop
what year is the truck?
Old 10-29-2010, 07:40 PM
um its a late 1994 wich makes it a 1995 7.3 turbo diesel f250 ford.well i didnt put the new pump on but it was happening with the old one too.wich cooked itself because i didnt know what was wrong originally.the guy who did the pump thinks its an o ring inside the engine.or it could be the injector o rings.so i changed the o rings and it didnt fix it.it's actually worse now.i havto fill the pump by hand everytime to get it to start each time.before i did the injectors it was only when it sat overnight.
Old 10-30-2010, 06:13 PM
Old 10-30-2010, 08:16 PM
drives a ranger
ok then yes there is a check valve in the hpop that stops oil from draining back, probably went bad
Old 10-30-2010, 08:31 PM
joe, are the 95 hpops the same as the 97+?
Old 10-31-2010, 08:53 AM
drives a ranger
nope. the 95.5 and 95s are the same, 96 and up arent the same but they are interchangeable
Old 11-01-2010, 10:05 AM
Just did a lot a talking with Lisa about this. THink we have it worked out now.
Old 11-01-2010, 06:34 PM
Johnny Law Brown
So what ended up being the fix to the problem
