95 smelling fuel - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-12-2010, 04:39 PM Thread Starter
95 smelling fuel
when i shut my truck off after driving i smell fuel. Cant see any fuel in th valley of death and dont have any framerail line leaks the only place i can think of is the lift pump. Has anyone had those lines at the back of the heads leak i cant see them to see if they are leaking.
kevinwoo11 is offline
post #2 of 4 Old 10-14-2010, 01:37 AM
Feedback Score: 3 reviews
yes they have small square cut seals in the connections and you'll develop a seapaage leak. Also the tin banjo bolt will leak too. Have you changed the fuel filter lately?
96F350KID is offline
post #3 of 4 Old 10-15-2010, 06:10 PM Thread Starter
bout 3000 miles ago i have seen the lift pumps leak but not the lines behind the heads. Do you have to pull the trans to get to those lines. If so a 30 minute project just turned into 5.
post #4 of 4 Old 10-15-2010, 08:22 PM
Oh no you can see them just follow the line from the banjo bolt to the back of the heads. Its unlikely that they would leak into the valley but it is a place to look. Also the pet**** for the bowl could leak if you recienty moved it. Unlike the 99-03 trucks where they'll just all of a sudden leak. If seen ones that if you move them once they wont go back all the way and drip fuel.
