buddy needs help - Ford Powerstroke Diesel Forum
Old 10-06-2010, 11:02 PM
buddy needs help
well my buddy is in minot north dakota with the air force, just got sent up there about a month ago. here is the problem he is having.
This was all posted on another forum
To start off the truck is a 97 f-250 crew cab short bed 4x4 auto, with 260k miles. I figured I might as well do some maintence on it before winter hits because it had some blue smoke and was hard to start. I installed a stancor GPR and that didn't help. Next I installed some injector seals and new glow plugs. The truck started up and smoked a bit (from the oil that leaks down into the cylinders). I let it idle for close to half an hour and drove it around base. Truck ran amazing and had a ton of power. Couldn't get it up to speed since the speed limit is only 30. Well I got on the main highway and it ran great all the way until about 70. Backed off and started cruising at 55 and the truck started shaking badly. Took it out of overdrive and the shaking went away.
Well about 30 seconds later I decided to get on the throttle more and nothing happened. I went to WOT and it barely started to build mph. I pulled over and the truck was running horribly. It sounded like it was only running on 5 cylinders. I had to put it on the high idle setting because I was afraid it would die. I then turned around and headed back to base. It took me close to a mile to get up to 55mph again. I had to let each gear rev out until about 3k before it wouldn't rev anymore, and then manually shift it to the next gear.
I drove about another mile before I pulled into base. As I was slowing down it just completely stalled and I coasted to the side of the road. It wouldn't start again. I had to get towed back to the dorms by a chevy I started reading online and figured maybe the UVCH might possibly be messed up. So I replaced both of them and the valve cover gasket with no luck. Truck still wont start. The HPOP resi is full to the top of the threads. The truck just keeps cranking and cranking with no indication of even trying to start. I cranked it for about 20 seconds then got out and pushed in the valve on the side of the fuel filter and fuel just dribbled out.
Tach is moving
No smoke out exhaust and can't smell in there when I snif after trying to start
Cel stays on after long cranks. Was NOT on when truck was running like crap before it died
Going to try and obdII scanner tomorrow
Fuses are all good when I physically checked them, going to buy a multimeter to check them
Don't know how to check fuel bowl heater
Fuel filter has 5k miles on it fyi
Fuse number 22 is good
Just replaced the CPS and no luck still
I tried 2 30 second long cranks, unplugged the IPR sensor I believe it is, another 30 second long crank, plugged it back in, and another 30 second long crank. No luck or any indication it was going to start. Yes I took about a 5 minute break between any of the starts. It was interesting though on the first 30 second long crank the oil pressure gauge didn't move at all. It wasn't until about 7-8 seconds on the second crank that it started to move.
Can anyone help or point me in a direction. I am not making much money, and don't have much free time so it might take a while to fix the problem. Would rather not throw money at parts if I don't have to.
Old 10-07-2010, 02:49 PM
Feedback Score: 3 reviews
Take the IDM which is on the fender and shake it. Does it sound like waters in it?? It sounds like a bad IDM In 97 they had a seal problem with the 97's and caused water to get inside. Everything from no start to running on 4 cyls occurs.
Old 10-07-2010, 02:57 PM
Shaking the Bush Boss
Bad IDM, bad IPR valve, If its not smoking while cranking, shes not getting any fuel. If at all possible, swap IDMs with a friend to eleminate it.
