95 7.3 rough idle - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-05-2010, 06:15 PM Thread Starter
95 7.3 rough idle
95 ford f-350 7.3 has a shake and a irregular idle but runs fine going down the road.can do a injector buzz test with scan tool and shows no trouble found. no dtc's no chip change fuel filter every 10,000 miles oil is in good shape changed under 1500 miles ago. was wondering if i had a problem with the idm or maybe fuel pump related. any advice will be appreciated.
rvrhauler95 is offline
post #2 of 4 Old 10-07-2010, 03:44 PM
Feedback Score: 3 reviews
Check fuel PSI. Is it a stick or auto? Check for any tiny fuel leak bowl, valley, fuel pump, rear lines, quick disconects that are viewable from the driver side wheel well.
96F350KID is offline
post #3 of 4 Old 10-10-2010, 05:45 PM Thread Starter
it has a automatic. will check for fuel leaks thanks
post #4 of 4 Old 10-10-2010, 09:25 PM
Ok also check the fuel bowl screen
