1995 f250 diesel leak - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-01-2010, 09:58 PM Thread Starter
Powerstroker 19's Avatar
so after hours of hunting down my diesel leak i found it on the back of the fuel bowl...it is coming from a sensor on the back bottom part of the bowl almost at the bottom...it is leaking out of a sensor with one wire going to it. does any one know what this sensor is so i can replace it?
Powerstroker 19 is offline
post #2 of 3 Old 09-01-2010, 10:42 PM
williamsadams's Avatar
I just replaced the wire harness for the fuel heater/water in fuel sensor. This harness had a wire that plugged in exactly where your talking about, but it also had two other wires that plugged into fuel bowl on drivers side. I know the larger oval looking plug on drivers side of the bowl is plugged into fuel heater so maybe the one ur refering to is water in fuel sensor.
williamsadams is offline
post #3 of 3 Old 09-02-2010, 01:12 PM Thread Starter
i pulled the sensor out and there was a little black blug pype thing that fell out after i unscrewed it...does this sound like the W I F sensor?
