95' 7.3 shuts off while goin down road - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-01-2010, 07:39 AM Thread Starter
i have a 95' 7.3 F-250 with a 5 speed and when i am driving down the road the glow plugs will cycle. they will do this 4-5 times then the truck shuts off. sometimes it will restart and other times i end up pulling it home. im lost
powerstrokekiid is offline
post #2 of 12 Old 09-01-2010, 11:24 AM
charlie-2's Avatar
not shure about the plugs but when my cam sensor went if ya let it sit it would start, run for a little then shut off or it just wouldnt start i dont know if the cps dose the same thing in an obs but thats what my problem was
sold..
2000 f-350 sc sb/ hualer/dd 2008 f-550 crew cab and 9ft aluninum flat bed. job 1
spartin tunes, legal dpf system....
banks speed brake and full egr delete. new
f-250 2008 cc sb 6.4l stock tip side dump and home made dpf delete. home made full egr delete. h&s 300 afe stg 2. air bag/ seat belt de active mod, dry rotted tires, front bumper mia.
charlie-2 is offline
post #3 of 12 Old 09-01-2010, 12:43 PM
atvrider93's Avatar
Quoted: 8 Post(s)
cps = cam position sensor
that sounds like it could be your problem. might as well go ahead and swap it
atvrider93 is offline
post #4 of 12 Old 09-01-2010, 05:37 PM
Sometimes mine will just shut off while running at idle, but it will start back up. Everything fuel filters is all clean or new. Havent figured this out yet what it could be. Mine is a 97 5 speed 2wd dually.
shelby2010 is offline
post #5 of 12 Old 09-01-2010, 06:58 PM Thread Starter
i have already put a cps in
post #6 of 12 Old 09-01-2010, 09:54 PM
Powerstroker 19's Avatar
How long ago? cuz mine had the same symptoms and i got a napa cps and it worked for abt 3 days and went out again... so i went to the dealership and got a ford cps and it hasnt let me down since
Powerstroker 19 is offline
post #7 of 12 Old 09-01-2010, 10:48 PM
williamsadams's Avatar
I hv a 95 350. I hv replaced cps several times. some work some don't. make sure u get the correct one. find a international truck dealer to get correct one and make sure u shim the sensor.
williamsadams is offline
post #8 of 12 Old 09-02-2010, 06:41 AM Thread Starter
k i will try a other cps how do u shim it
post #9 of 12 Old 09-02-2010, 06:44 AM Thread Starter
was ur glow plugs comin on while drivin down the road
post #10 of 12 Old 09-02-2010, 01:16 PM
i dont think they were ... the wait to start light was off so i dont know? ... and there were a certain few motors with a set of serial numbers that had a larger gap between the sensor and stator ring...these require shimming...ill get those part numbers for you tomorrow when i have access to all data again...on mine when the sensor went out i just plugged the new one in and it worked fine
